1 - 9 of 9 Posts
Does anybody else have this proplem? Sometimes, it will unlatch with just a slight bump and sometimes it takes a pretty good thump. All the latches still work like they should, so, I'm thinking it's just out of adjustment. Any thoughts?
YOu could take the back gate panel off and check the solenoid back there. Mine was loose one time and the bolts were about to fall out, and I tightened them up.
The squeek is the CHMSL housing rubbing on the endgate trim. You will see a shiney spot on the plastic where they rub. A wipe of silicone grease will stop the noise. Check the handle bolts for tightness. I am not aware of any adjustment to increase the space.
I can't seem to get my hatch to lock at all! I have tried useing the power locks, and tried locking it manualy and still nothing! any guesses guys?
Anybody found a solution to this? My wife just told me last night that her window is popping open while riding down the road. :(
Discussion Starter · #9 ·
The endgate lock sense switch in the right side of the tailgate is misaligned or bad. - Jim
1 - 9 of 9 Posts
