Hobbs switch is the best way to run dual pumps imo. Secondary Activated at boost levels and doesn’t leave you stranded if one pump fails.
Thank you for chiming in, with a good and safe way to do this. When you mention the set on and off points, can I assume these set points would be defined by engine RPM's? Or is this based upon boost as well? Thanks in advance for explaining a little more. At this point I with the car, I am in deeper water that I know how to swim out of.Something with a thick film film transducer and some electronics so you could set on and off points separately would be more to my liking.
Any idea of the cracking pressure?I'm using the ball style check valve from Vibrant - No issues to date
Vibrant Website said:Vibrant Performance Ball Style Inline One Way Check Valves are lightweight and constructed entirely from 6061 Aluminum alloy. Our Ball Style Inline One Way Check Valves are designed to prevent flow back of all varieties of fuel, oil or coolant. Vibrant Check Valves will stand up to the most rigorous operating environments and are capable of handling temperatures ranging from -30deg F to 400deg F and operating pressures up to 300psi. All Vibrant Performance Ball Style Inline One Way Check Valves are available in anodized black only. Cracking pressure is adjustable between 2-5 psi. Use Thread Locker when setting cracking pressure. Flow Direction: Male AN to Female ORB. [\quote]
I'm running a 7.5psi racetronix Hobbs switch to activate my second pump. Probably 2k miles of logs and pump activation has never been an issue. No fuel spikes, no bogs, no lean spots. It works pretty seamlessly, even with a PD blower that acts pretty much like an on/off switch going from 0 to 16 psi an instant.On Saturday, I installed a Powermaster 200 amp alternator to deal with the extra fuel pump. I also crawled around under the car considering various fuel line and wiring options. I decided the tank was too heavy, and the whole job was too much for me, so I was at the mechanic yesterday to make an appointment.
The mechanic suggested I run the auxiliary fuel pump with it's own fuel line all the way up to the fuel rail and Y in (with the other pump) at the fuel rail. The pump activation was discussed and my mechanic recommended a Hobbs switch with a timer. I had never heard of such a thing! I was very interested to see Gerry mention similar when I checked in here today.
Keep the opinions coming. I find the comments very helpful. I don' mind negative comments either. I am here to learn, and I do respect differences of opinion.
My mechanic LOVED what Gerry suggested:I'm running a 7.5psi racetronix Hobbs switch to activate my second pump. Probably 2k miles of logs and pump activation has never been an issue. No fuel spikes, no bogs, no lean spots. It works pretty seamlessly, even with a PD blower that acts pretty much like an on/off switch going from 0 to 16 psi an instant.
Only thing I don't like about a hobbs switch is if the switch DOES fail at any point, the engine will still be getting fed, most likely, with enough fuel from the primary pump to continue running at WOT but lean out catastrophically. That's why my whole setup kind of terrifies me, knowing everything is hinging upon one little switch working at WOT. Tossed around ideas of hobbs switches run in parallel for redundancy, LED lights wired to the switching side and in the end the best solution I came up with was just to pay close attention to my wideband at WOT and possibly set up a warning light for my fuel pressure gauge.
I've been using Hobbs switches since I was 17 years old (without a failure), but I do have a lot of money into this version of my engine, so overkill is cheap insurance. I think Gerry's is a great idea, that will work.Gauge with low pressure warning that is programmable?
Set a couple pounds below your safe pressure ?
2-1/16" Fuel Pressure Gauge 0-100psi (w/ warning)
They can be ordered with an output to run one of their blinding shift lamps.
I have this set up on my oil pressure with the shift lamp right behind the oil light lens in the dash.
The Sano King hath spoken 😂Judgements withheld until you shorten those hose clamps![]()
That looks like stage1automotive. Is Rob doing the work himself?Picking the car up tomorrow
Yes, Rob has done a lot on my car.That looks like stage1automotive. Is Rob doing the work himself?
