1 - 14 of 14 Posts
I recently purchased a remote start from a forum member here, it's a code alarm sure start lx. I was wondering if anyone could help with the wiring. I have the wires and relays the remote start came out of a 96 impala and i want to it in my 95 impala. Im looking for wiring diagrams and any info. I've put in alarms before but not remote starts. The remote start has an alarm with it. Any help would be great.
IMPALA 94-96
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 BROWN Ignition Switch Harness, (check engine light)
Accessory Orange Ignition Switch Harness
Tach Red/Black Or Pink/Black (-) at Multi Coil Pack
Neutral Safety Wire Orange/Black Gear Select Switch
Brake Switch White Brake Switch
Trunk Release Black/White Switch
Trunk Pin Dark Green (-) Driver's Kick Panel (Rear Body Harness) (96)
Parking Lights Brown Light Switch
Head Lamp Yellow Light Switch
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Behind Driver's Kick Panel
Door Unlock White Positive Trigger
Horn Wire Black (-) Steering Column
CAPRICE
Tach White Or Purple/White (-) At Coil V8 or Multi Coil V6
Trunk Release Black Switch
Door Trigger Blue/White (-) Driver's Pin Switch
__________________
(95 caprice classic tow package! 3.73,
i didnt use mine i just ripped it out the alarm its pointless plss more work i just recently installed a alarm in my 9c1 very easy
The unit I have is used and came with 2 relays that are already wired to the remote start harness so I'm guessing that I need to leave those connected and just wire up everything
Send me your email addy in a pm I'll send ya the diagrams with where to tap each wire to
The hood switch should be hooked up so the car doesn't start with the hood open on accident if you are working on the engine
i dident use it. cause i dont like my alarm arming itself after i unlock it. so i dident need. it
ive looked at every diagram there is and i couldn't get it to work with a relay the alarm output is neg for my kill start
1 - 14 of 14 Posts
