Is there a way to repair scuffing and scratches on interior plastic. See my attached pic.
You might be able to sand them lightly to remove the high spots, then paint the panel with SEM Color Coat. Anything else will probably give you a difference in sheen. They are probably ABS, and solvents do not affect it to any degree.
depending on how deep your scratches are
you can use a heat gun if they are just scuffs, but their is a high probability that you ruin your parts
if you actually need to repair deep scratches or gouges
