I’ve been searching the forum for information related to the replacement of the General Motors OEM carpet. I’ve found no fewer than ten threads about this very discussion. The only reason I’ve started another conversation is that everything I found was VERY old. Most threads were dating 13, 17 and 18 years back. I read every single line of every carpet discussion while I was simultaneously researching and cross referencing anything I could find with the Google Machine. I discovered what seemed to be a few highly recommended options, only to find websites that hadn’t been active in years. Personally I really like black carpet in a 1994-1996 Impala SS. However, I’ve kept my car completely stock for the 23 years we’ve owned it. I even used to buy the sorry BFGs these cars were originally fitted with. I’m going to post the 4 manufacturers description that I’ve condensed quite a bit. Hopefully this doesn’t break any rule or policy. Price is not what I’m concerned about. Quality is what I’m looking for. Anyone’s input or experience with any of these companies would be greatly appreciated.
# 1~Original Equipment Reproduction (OER)
Factory original quality for less
Direct fit replacement
Installation is identical to factory unit
No vehicle modifications required
Original style 36 oz. jute padding attached to the underside of the carpet
Designed with the latest software and manufactured with modern tooling
Heat stamped, preformed and trimmed to fit your floor pan
Each product is designed and manufactured to duplicate the original part as closely as possible. Most OER products are officially licensed as authentic restoration products. Each OER part is manufactured to original specifications, down to the smallest detail.
OER® was established in the early 1980's to manufacture original equipment reproductions where every part is meticulously reproduced to exact factory specifications. All OER® parts are reverse engineered or manufactured using original blueprints when available to ensure the closest possible reproduction available on the market. When available, original factory tooling is utilized to insure complete originality.
# 2~Newark Auto
Sewn-To-Contour Replacement Front and Rear Carpet Kit by Newark Auto®. Carpets are made from time tested patterns made from original floor pans or carpets. This product is made of high-quality materials to serve you for years to come. Designed using state-of-the-art technology and with customers in mind.
Features:
Replaces vehicle's original carpeting
Made from 100% tufted, loomed carpet
Custom made for each vehicle
Seamless, press molded style
OEM quality carpeting
Drivers heel pad attached
Includes: Underpadding
Newark Auto® was established in 1907 as a trim shop, refurbishing upholstery in horse drawn carriages. However, as the popularity of automobiles grew, Newark Auto shortly changed its focus to automotive parts and accessories, manufacturing everything for the interiors of cars from replacement carpets and seat covers to headliners and convertible tops. From that time the company has grown to become the largest supplier of automotive replacement carpets and replacement rubber mats for trucks and vans to the do-it-yourself market. In its manufacturing facility in West Orange, New Jersey, Newark Auto makes top-quality automotive accessories.
# 3~ACC~Auto Custom Carpets
Factory Fit Carpet
ACC. Made with true automotive grade carpet, we offer seven original materials plus our premium Essex carpet.
Material: Molded-Cutpile
Vehicle Placement: Complete
No Heel Pad On The Original Carpet.
• Great sound and heat barrier.
# 4~CAR Motorsports
OEM approved molded carpets to ensure proper fit and appearance. Made by an actual carpet manufacturer and feature an advanced dye process to avoid fading and ensure long lasting color. The dye process is performed on the fibers prior to assembly into carpet. This ensures the best and most fade resistant color. Our carpets are cut to ensure you have ample material at the edges near the door sill plates and under the rear seats.OEM Plus Premium Cut Pile Carpet and OEM Plus Ultra Premium Carpet.
Rubber hazmat backing is an option on all of our carpets. This rubber backing was used in some factory applications (Buick Reatta, Cadillac Allante, Pontiac Trans Am, etc.) as a sound deadening and heat insulation agent. The purpose was to insulate the interior from heat and reduce exhaust and road noise in the car. This rubber backing is available on all of our carpet sets and is more economical and effective than installing Dynomat. If you have a loud exhaust system, the difference will be dramatically noticeable. Also, you will notice a substantial difference in the interior temperature in your car. We highly recommend the rubber backing, especially for those owners with performance exhaust systems.
CAR Motorsports carpet features include:
Molded to your factory floor pan for an OEM fit.
Generous trimming to ensure there is always enough at the edges.
Heavy 40 ounce jute padding.
Die electrically sealed heel pads.
Superior quality that exceeds OEM specifications.
OEM Plus Premium Cut Pile Carpet Colors A 100% nylon loop carpet similar to what is found in most domestic cars since 1974. 800 series cut pile is perfect for late model restoration and fix up. Available in 53 OEM Colors.
OEM Plus Ultra Premium Carpet Colors A 100% nylon cut pile carpet manufactured with over 40% more nylon fiber than our standard OEM Plus series cut pile. Our Ultra Premium carpet will give any car a super plush luxury identity. Ultra Premium carpet is available in 21 late model colors.
So what’s the verdict?
# 2~Newark Auto
Features:
Factory Fit Carpet
- New, Molded Reproduction Carpet
- Made With High Quality Carpet Materials
- Carpet Kits Are Produced From Templates And Dies That Were Created By Using Original Floor Pans Or Your Specific Vehicle Application.
- Padding Varies By Application, But Most Have A Heavy Jute Pad Around The Foot-wells
- Installation Will Require Trimming Around Edges And Cutting Holes For Items Such As Seatbelts
- Increases the overall look of the carpet after installation.
- Add-on option for most any Molded Carpet.
- Approximately 45 mil thick EVA material.
# 4~CAR Motorsports
