I have a leak coming from the pump it appears. I can see it dripping down from unit area, does not appear to be any lines unles it is one at the pump.
I really do not want to do this job. Ha ha
well, when I saw the pump sitting behind the coolant lines I figured it would save me some headache trying to wiggle the pump around the lines, and it doesn't take much if you pull the return line on top of the radiator first, then the line leading into the block (plus that reduces chance of getting coolant on optispark). and yeah i got the puller from Advance but ended up breaking the handle on it. But a big screwdriver did the same job holding the puller in place.
