1 - 9 of 9 Posts
Guys,
I'm debating on whether or not to buy only a set of tires, or if I'd like to go thru and get a new set of wheels.
That being what it is, is there anyone y'all can recommend for a Tire-N-Wheel package? I just did a quick search and Tire rack & Summit both seem to have slim pickings for wheels.
So I'm debating as to buy a set of (4) tires today thru Discount Tire to get a black friday discount, and then get a new set of wheels down the road, or get an all in one package.
Any thoughts? Any good sites for 5X5 wheels for our cars?
Thanks!
Well you left it wide open for kibbutzing, but would be better to narrow down the field a tad. IDRecall if you got a wagon or 'just' a Caprice/SS, but I don't think you're a FW brethren. But appears you're currently running 20's per sig.
So all that done, I can only mention I would not think to default to TR for much outside of a narrow band of regular customer sale demograph (i.e. bore ring). I happened on multiple wh/tire combiners when looking for replacements on my FWB, but if you want to consider oem take-offs here's where I ended up = very good quality, fair prices and painless ordering/delivery. There's even 18-19-20 stockers if you're staying with oversize:
Thanks, yes I think I would stay with 20s. I've got 8.5 on the front and 10" Wide on the rear. I've got the '96 Caprice and upgraded suspension.
I do like the look of 9C1 wheels, if I could find them oversized I'd like that a lot. All I know is that I think I've got 5" of backspacing.
I've also got a set of 1" adapters which I haven't installed from one of the recommended suppliers thru the forum.
I also should have said Cyber-Monday pricing instead of black friday, but it's all the same....
Phuuuuu.......k, you got spacers? I've always liked the wheel-flush-to-sidewall look on a B-body. You're a perfect candidate for some FWD offsets then if you can mod your spacers or get new ones with 5x(120 is it?). Just more options.
I could swear there's a company doing oversize cast and steelies in many old 15" oem patterns FWIW.
Okay, since I've never really researched wheels & tires before (I bought the current set thru Craigslist back in 2010) I hadn't thought about using adapters to change to a different hole pattern, I only thought of them in the spacing they provide. My current setup has the rears very close to the frame, that's why I bought them. But I didn't really sit down and do the math/engineering to see if they will work, and not push the tire into the wheel well.
Now the possibilities are even more than what I first thought of. I'm glad I started the thread after all.....
Considering 5X5 has pretty much left the building nowadays, and seeing all the neat alloy oem choices out there now, options really open up with combo spacer-adapters.
I fretted way too much putting something decent on my latest FWB, but learnt a bunch along the way:
These folks know B- bodies quite well, and ought to be able to help you confirm whether you can get a wheel you like to fit under your car:
Okay, since you have listed it a few times in your writing, I've got to ask since I'm not familiar with the acronym regarding our series of vehicles..
What is FWB?
Thanks!
Fleetwood Brougham. You outta drop by, it's where all the neat guys hang. ::Hawaiian hand moji::
Next class; RMS, RMW and OCC ;)
.....is there anyone y'all can recommend for a Tire-N-Wheel package?......
I have a set of 18"x9.5" Corvette wheels that I used with 285/40-18's (same diameter as stock SS wheels tires).
Note.....I do not have the tires available. If you're interested.....PM me your email (don't have it stored anymore) and I'll send pictures.
KW
1 - 9 of 9 Posts
