So the original bolt threads got a little messed up due to backing out part way so I need new ones.
1st - The correct size is 7/16 - 20 LH correct?
2nd - ARP / Ratech / Mr. Gasket
Normally I go with ARP but why are they 70 dollars compared to 15 for each of the
others? Recommendations?
- Brian
Nothing wrong with OE--ARP is good, but probably overkill for street use.
LH thread, correct
14066913 B BOLT,RR DIFF R/GR(7/16-20X7/8)(HEX) (item #8)
14066913 replaced by 12479028
(info from GM Parts Direct - reference only)
GM PART # 12479028
CATEGORY: Ring Gear Bolt
PACK QTY: 5
GM LIST: $4.08 (per bolt)
OUR PRICE: $2.37
Thanks for the OE part numbers. Summit racing had Mr Gasket or ARP as the only choices. $14 or $75 respectively. $35 for the OE from RMS seems like a good compromise. I'm going to check the local dealership tonight to see if I can get them for close to the same.
I've always been a little weary of Mr. Gasket parts as they seem to make every for everything. They're like the Wal-Mart of Random Auto Parts.
- Brian
