Hey guys,
It is said not to reuse the ring gear bolts.
WHat if you tightened the ring gear and you realize during set up one of the bolts came loose. You of course, don`t want to take the chance so you decide to loosen all of them and re-install them using a good amount of red Loctite.
Does that make sense or do they need to be discarded once you tightened them, little matters that the rear end was never installed in the car?
I think I will reuse them but if you tell me my rear end will explode (not because of the beans I just ate), I might change my mind
Thanks for the tip, that was my plan, to do them one at a time.
I did loctite them, but only with whatever small quantity was in my install kit. I'll get a real tube tomorrow.
