That's a pretty conservative setup. After running that setup, what would be your next upgrade? It looks like crazy fun to drive. I can't wait to get my girl out there!
My buddy has a 97 t-bird that he tracks. It's pretty big too. We rebuilt the engine and added bigger heads cams intake, a fuel cell, coilovers, big brakes, radiator. That thing had crazy body roll. The fenders were cutting into the tires! We adjusted the coilovers and took her back out. We blew the trans and called it a day. Got it on the lift to see what the problem was. We forgot to bolt the front sway bar to the lower control arm! Haha! We ain't pros that's for sure!
Anyways, that's where I got the idea for the rear IRS swap.
That axle looks pretty awesome. I heard about the back yard way to heat the axle in the right spots to get camber and toe. Wears the ball joints though. I'd go with a heidts, roadstershop, or art Morrison irs for about the same price. This swap is pretty low buck.
Did you go with the f2b conversion or did you diy it?
I'll have to check the roll cage thread. I'd like to go that route but I enjoy the luxury of the 80's interior. I'd like to keep it sleeper/cruiser. I have an 84 Corvette that I'd like to put a cage in. I'm building a carbed 350 for it. I have a zf 6speed for it. That one is gonna be all track.
They are adjustable as in choose your camber by what axle ends you buy.
We are running - 1.5 both sides currently
One of the big pluses is the wheel bearings
No play, no pad knockback.
This car has kind of been back burnered as more " exciting " stablemates showed up but the neg camber was a big improvement
Conservative as in not spending money I don't have, yes! Haha. It's at the point where any mods basically cost me track time, since I can't afford much of both at the same time. From here, just trying squeeze out as much performance as I can on the basic setup. I just recently picked up some fresh stock lower front control arms with Delrin bushings and shorter than stock tubular up arms with tall ball joints to better the camber curve under compression and be able to run more than -2.0 camber up front. Currently having to overinflate front tires to combat outer shoulder wear, so a bump in front camber should help. From there it'll be a multi piston real deal front brake upgrade to combat warping inboard backing plates, which will likely necessitate a bigger badder wheel/tire package, which will necessitate a road race baffled oil pan due to higher cornering loads, etc etc. Snowballs quick, but trying to keep it in check. Bigger stickier tires would be HUGE for me, but then, obviously more load on the brakes and possibility to starve oil. Eventually I would like to do a slightly tweaked LT1 with some mild head/cam work to unlock some more RPM and HP, but not before addressing brakes and tires.I bought the IRS on the 11th and it's been stuck sitting in a shipping warehouse for the past 2 weeks. Damn Corona! I been itching to get going on this swap!
Your new upper and lower control arm setup should make a huge difference. When I first started tinkering with the idea of tracking my Caprice I thought about using factory g-body uppers and tall ball joints. Not sure how well it would work but they would definitely give it more camber. I'm running tubular control arms made for 2nd gen f-bodys. They are way cheaper than b-body arms. They are essentially the same geometry.Conservative as in not spending money I don't have, yes! Haha. It's at the point where any mods basically cost me track time, since I can't afford much of both at the same time. From here, just trying squeeze out as much performance as I can on the basic setup. I just recently picked up some fresh stock lower front control arms with Delrin bushings and shorter than stock tubular up arms with tall ball joints to better the camber curve under compression and be able to run more than -2.0 camber up front. Currently having to overinflate front tires to combat outer shoulder wear, so a bump in front camber should help. From there it'll be a multi piston real deal front brake upgrade to combat warping inboard backing plates, which will likely necessitate a bigger badder wheel/tire package, which will necessitate a road race baffled oil pan due to higher cornering loads, etc etc. Snowballs quick, but trying to keep it in check. Bigger stickier tires would be HUGE for me, but then, obviously more load on the brakes and possibility to starve oil. Eventually I would like to do a slightly tweaked LT1 with some mild head/cam work to unlock some more RPM and HP, but not before addressing brakes and tires.
Yeah I was alluding to the heating/torching of the rear housing to get some crude camber and toe. No ball joints back there, but could arguably put a little more stress on the ends of the axle splines.... however it sounds like a lot of folks "get away with it" for a loooong time due to slop in those interfaces anyway.
My swap was a homebrew setup from another forum member who likes to DIY. He sold me the whole swap some years ago at a bargain price. Built his own F-body pedal bracket. Not as pretty, but wayyyy cheaper and it works!
Copy that on swapping axles for rear end camber adjustment. Pipe dreams for me, but cool nonetheless!
Those upper arms, ball joints, and fancy bushings should help you alot. I think I'll add some tall upper joints to my set up. The oil pan I have is a circle track claimer 8qt oil pan with 7 trap doors. It's cool but I had to notch the frame to fit. I took the trans cooler and made it into an engine oil cooler. How does the fuel tank do. Any starvation on the track? That's my only worry.Man that car looks clean!
I found and bought these tubular upper arms thanks to a fellow forum member:
$320 WITH QA1 rebuildable tall upper ball joints and free shipping?? Hard to beat! Received them a day or two ago, and they look great.
Driver mods are always the best mods!!!!
Yes I'm happy with the spring rates for a car that still sees regular street duty. If I were doing it all over again, I would likely opt for the 800inlb front springs though. Pretty sure Moog offers a pretty wide variety of rates for their "truck" springs". I still get a lot of brake dive, but I could also get a better/adjustable front shock option to help there too. For the Vogtland rear springs, they may not even be available any more? No clue. I did cut about 3" length of the upper pigtail end to get the car to sit level with a full tank of fuel. Not a tight fit around the frame nipple anymore, but never had any issues in the last 15 years. I'm pretty sure the Vogtlands were a mildly progressive rate that was in the neighborhood of 250inlb? I like the rear soft - it's MUCH more forgiving to sloppy driving, and seems to be able to put the power down sooner. Easy to correct if I get overzealous with my inputs.
That IRS looks beefy, especially compared to the stock stick axle Any idea what it weighs?
What style of shift knob do you have? I've got a plain maybe 2-3" diameter round ball and I love it. A little slick for sweaty hands slamming gears, but I bought some nice Alpinestars Nomex driving gloves with silicone grippers on the palm and fingers to combat that for hot and heavy track duty.
