Ah, yes. I read that and promptly forgot it.The picture isn't his so nothing seen there is relevant.
Yes,1416-16, If non self align rockers,what to do?Your first post , you said you 1417-16 which is a set of self align for a V8 which would be OK.
Now you say you have 1416-12 which are NON self align . If you have non self align rockers , no wonder they wander off the valve tip!
BTW 1416-12 is only 12 rockers so one can only guess you mean 1416-16 ??
Stock iron heads with pressed studs ,what to do?
For sure. I didn’t realize how little the press in studs could take until recently when I started looking into rebuilding a set of heads. IMO, They are basically ok for a stock rebuild, but aren’t appropriate for any kind of performance.To add , 1.6 rockers + more spring pressure on stock pressed studs not the smartest plan even with a stock cam.
Sure lots get away with it,,,,,,,,, large number of cases , it will pull studs.
Seen it more than twice first hand ,where guys havn't got away with it.
PM sent.Thank you all , I will change the rockers
