Hello,
has anybody bought the rubber flooring for an impala or a caprice?
from looking it seems sedan and wagon are the same in regards to the carpet.
my carpet is really nice, but after all the mold issues, i think i might just do one of those rubber sets. i am going to pull the existing carpet and run it bare for a while to check for more leaks...
does anyone have experience with these aftermarket, and if any are quality?
like these, 1991-1996 Chevy Caprice Molded Vinyl Flooring 1991, 1992, 1993, 1994, 1995, 1996
1991 CHEVROLET CAPRICE 4 DOOR VINYL FLOORING
thanks!
I bought one. Its a little thinner than the factory rubber flooring. The fitment wasn't so good, it seemed a little loose in some areas. It looked like it could fit better with some work. I happened to find a nice used OEM rubber floor so I ended up not using the vinyl. If you go that route I recommend first trying to install it over the existing floor, maybe that would help with some of the looseness.
thankyou.
if its a little baggy, and not enough to cause wear spots i wont care. just needs to be functional.
if i could get on oem one i would though, where did you find one?
unfortunately my carpet that is in otherwise amazing, mint looking shape, has mold in it....
