Any one use denso O2 sensors? If so did the work O.K.? I replaced mine with these and my car seems to have what I think is a lean miss! I also have replaced and checked EGR, EGR solenoid, Intakes gasket, Opti, coil , AC delco plugs, wires. no CEL on or history codes.
Any one use denso O2 sensors? If so did the work O.K.? I replaced mine with these and my car seems to have what I think is a lean miss!......
The concensus is that if you use any O2 sensors other than OEM sensors, you're taking a big risk.
That said, the miss may not be caused by the O2's.
KW
