1 - 20 of 30 Posts
So i reran my system today. I upgrade my ground wire to 0 gauge from 4 gauge and mounted it to the rear seat belt bolt. Now all of a sudden my Mono amp is getting horribly hot an shut off mins after song plays. I never had this problem until I hooked the 0 gauge ground up!
Grounding woes
So,what's grounding your body? If it's the little wire going to the fender from the battery,you're asking for trouble big-time. Much of the wiring harness depends on a grounded body,and now you're pumping power into it. You could catch something on fire doing stuff like this. Ground the body to the motor pronto.
So should I go back to the 4 gauge ground wire since I'm running 4 gauge power wire? I read on the audio forums that the power and ground should match.
Sent from AutoGuide.com Free App
As 1slow96 stated make sure your body has a good ground as well, but place for high power amplifier grounds are on the frame itself.
Now as far as putting 4G back on for ground. NO. What you read on audio forums is correct but misconstrued. IF you have a 4 G power you need to have a 4G or LARGER ground wire to match.
Where was it grounded before that it wasn't causing the amp to heat up?
My suggestion, for 0G ground wire, drill hole in body in a place you can run wire direct to the frame, burnish or sand frame to clean shiny metal, attach ground lead.
Pretty good video here to give you the basics.
Definitely make sure that your body ground located on the right fender next to the battery is good an tight and not corroded, it is good to check that as well.
Grounding woes
Absolutely wrong. The only reason to run ground cable the entire length of the car is failure to ground the body,frame,and motor to each other properly.
Grounding woes
I have quite a few grounding cables/straps. Most are one foot,or shorter in length. Motor/body, motor/frame, body/frame,etc,etc...
Grounding woes
No,my battery's in the trunk. There is a 2/0ga. power cable to the starter,and a 2ga. power cable to the aux. post. Battery is grounded to the body/frame with a 2/0ga. cable,and a 2ga. ground to body itself.
Grounding woes
May reduce your amp system symptoms,but you have grounding issues that are not going away by themselves. I would address them,pronto.
Discussion Starter #16
Ok so ill do this double check my amp ground. Run a 4awg ground from battery to chassis... chassis to engine... 4awg power wire from battery to alt... run 4awg power wire from battery to aux. How do this sound?
Grounding woes
Seems reasonable,probably better than what you have. I prefer heavier gauge.
Grounding woes
Gary makes good stuff,but anyone can learn to make their own. There is nothing magical about it. I get my cable/supplies from http://delcity.net
1 - 20 of 30 Posts
