1 - 9 of 9 Posts
I don't know if a lot of you already know this, but I just discovered this today with my buddy showing me this little trick..
After you drop the wire pull the carpet back and you'll see the factory wires..
Here is a pic of the passenger side rear..
Now running up to the trunk..
Ran out of matt..trunk is covered all the way up to this point..
Thanks man..My buddy came over and showed that to me..(I had 4 gage ran on the driver side) just for conversation what are the various reasons?
I ran mine that way long ago, thru the sweet spot below the heater that people recommended.
just be carefull of sharp edges going thru the rear seat/trunk opening, I think I put mine thru closer to the rear wheel well.
and fuse it up by the battery.
Right on thanks for the heads up..I have a extra battery in the trunk..So 3 circuit breakers..one after main battery, before second battery, and after the second battery going to the amp..I have some more things to do to the audio before I can post some more pics..cant wait to finally put my front door panels on so I can install the 6 1/2'' boston pro's and hook up the 4 channel..It's been a long time coming
looks sweet bro. i did the same thing last year when i upgraded my system!
I just like to have very heavy current capable/carrying wiring outside of the passenger area. The way you have yours is nice, I have seen some really shady installs in the past though. Chafing would be my highest concern, but it looks like you did it right :)
Thanks guys, I'll be sure to put loom for the entrance and exit so no Chafing happens..I still have to get my black carpet so the SS is still apart
1 - 9 of 9 Posts
