1 - 13 of 13 Posts
After realizing my underbody was compromised of rust and I developed a massive knock in my engine, Ive decided it's time to put down my black 96 fwb. :(
I already pulled the grill, headlights, signal lights, keyless entry module, all chrome side panels, headlight trim, tail lights, deck, interior door panels/switches, rear speakers, door speakers.
Let me know if anyone needs anything that can be shipped.
Another cool mod for any b-body is the under carpet AC/heat floor ducts for the rear seat area. It should include the 2 legs and the manifold fitting they slip onto.
You may want to list them up too if it has them. GLWS's.
I was going to ask about the exact same thing...
Oh wow. So those are under the carpet? Are they difficult to remove?
Yes and No.
Yes - the "Frog Leg" pieces run under the Carpet from the Manifold, along the Trans Tunnel and then under the Seats.
No - for the Most part the "Frog Legs" just Lay there and are only secured at the very end with a Plastic Push Pin. It should be obvious once you lift the carpet. I think there is 1 Screw that holds the Manifold piece on too.
Where are you located? Does it have gold or chrome emblems? I may be interested in some pieces.
Can you tell me if you have this bezel in good condition?
BEZEL
1 - 13 of 13 Posts
