When I built my car, I wired up a spare under hood fuse box mounted mirror image to the factory one on the driver's side and fed by a 2 gauge cable from the alternator. Came very much in handy adding the accessories I needed while keeping it all clean and factory looking. Allows me to have fuses, relays all in one place and all fed from the same source.
Currently (no pun intended) it feeds my twin fuel pumps, my supercharger heat exchanger pump and I also wired up another relay/fuse activated with key on and then ran 10 gauge wire from that into my cabin to power an auxiliary key on fuse box for lower draw in-cabin accessories like my aftermarket gauges and heated seats.
Everything has been fine so far, when I kicked the boost up from 13 to 16 I began to stretch the limits of the heat exchanger system and I know I could benefit from a higher flowing pump less affected by the large head pressures created by a trunk tank setup in a 2000000 foot long car.
The pump most CTSV/ZL1 guys are having the best luck with are Pierburg CWA 400's. I'd like to swap to one, but the pump COULD see as much as a 36amp draw (supposedly it is usually 15-20a on most setups, but will depend on how much resistance the HX circuit has). The pump will be PWM because there is no need for it to be running full tilt at anything other than WOT, but for road race events I'd like to throw a manual switch in to kick the pump on full speed all the time to keep the blower cool.
Anyway, looking for a way to safely wire this beast of a pump in using the factory fuse box, which may be a challenge being the metri-pack 280 terminals that feet the relay posts I believe would be stretched past their limits given the charts I have seen.
Any ideas on what I can do? Gerry had mentioned at one point in an older thread about running parallel relays. I'm thinking that might be the ticket.
I draw a diagram below to show what I was thinking.
Anyone see any issues with this, or have a better idea? I think I probably COULD run the pump on one relay being most times I don't think these pumps draw more than 20amps at max flow in most systems and probably won't be doing it for long periods of time, but i'd rather be on the safe side.
