anybody knows where I need to run the wire from to get the SCV to work on my tape player in a '94 9c1?
TIA
You pick it off the huge connector that bolts together under the steering column. It is held together by a 7mm nut. Take that apart and you can get to the wire to solder on to it. I dont have my manual handy, but thats the short of it. I will try to look up the cavity. I had to hit it for the astro install on my 94 9C1.
Peter May
