An upholstry shop should be able to make a new one for about $45. You will have to let them copy your old one, and transfer the fittings. It can then be installed on your old retractor.
That is another situation entirely. Did you check the for sale section. The color will probably be the same as an Impala. You can switch the belts from the PS retractor to the DS retractor if you find a good PS belt.
