1 - 14 of 14 Posts
Sedan Drum Brake Backing Plates 11-2"
As the title says, I am looking for bare L+R drum brake backing plates from a sedan , NOT a wagon.
(edit) 11 inch dia braking plates (/edit)
Please let me know what you might have shipped to Washington 98281
I believe the 11 by 2 inch drums are the size of the wagon brakes.
Discussion Starter #5 (Edited)
Well, I thought the HD disc drum sedan had 11-2 ( same shoe as wagon BUT narrow flange drum )
Like B4U
Part Number: 18002392
Part: Backing Plate
Part Notes: 11 brake, sedan.
As opposed to
Part Number: 18013844
Part: Backing Plate
Part Notes: Wagon.
Am I incorrect ?
Sedans have two different diameter drums available. The larger one is the same as the wagon I all respects.
Ok, number one, the sedan 11-2 drum can be put on a wagon but the two are not the same.
The OE wagon drum is substantially heavier and wider front to back due to the flange sticking out inboard of the backing plate.
Number 2 , I am not looking for a drum
I am looking for sedan 11-2 backing plates.
Compared to a wagon,
Different mounting pattern, different bolt size, different off set in relation to the housing flange
I can get a pair, but I have to remove the axles, and disassemble the brakes to get them. The are trapped behind the axle flange.
I have an axle out and not going to use drums. Its a sedan g80 axle so i assume it's the one you need. If fred can't help i could ship next week. I'm curious what top secret thing you are doing with them?
Fred, if you're browsing the yards, I'd be interested in the opposite, a set off a disc rear. Just backing plates and parking brake shoe/assembly. I'd source the rotor, bracket, caliper locally.
I've got a Fleetwood rear on blocks in the woods I could get them off of.
LMK if your interested.
Nab
Drums or discs? Didn't see any disc parts crossing to a fleetwood.
Drums or course!
Same drum backing plates as caprice B4U.
If your looking for disc brake backing plates,
I have those too.
I'd need $150 shipped (they're still on my parts car and
need to be removed which will take a couple hours of labor)
Nab
1 - 14 of 14 Posts
