It's as close as it gets that's presently on the market. It's as amazing a product as virtually any I've seen and worked w/. This isn't just mindlessly lauding praise. It's a fact. I did mine over 5 years ago and still looks OEM.Does anyone have pictures of comparing stock OEM gray to sem gray? I'm looking for some side by side pictures. I want to see how off the Sem paint is from stock or how close it actually is. Thanks
Great pictures! I know this is a revisited subject but I feel forum members love as much info as possible. Just for the record, what color codes did you go with? Your work looks really good. I'm pumped to do mine too. Thanks again!Just did mine last weekend. My upper dash was slightly darker than the lower. Now its just a little bit lighter. I can't believe you could get the colors to match any better out of a spray can. I'm very happy with it. Time will tell how well it holds up. I did my entire upper dash including the passenger airbag cover and three vents as well as the two rear speaker grills. It took about 1 1/2 cans of paint and about the same for the low luster clear coat. I used dish soap and SEM Vinyl Prep and a lot of elbow grease. Cost about $70.00. Well worth the money.
Before
After
I got my paint and prep from car quest.... if you're redoing the interior gray, get #15393Where did you buy the SEM paint & prep at, Stoney?
What clear coat did you use?Just did mine last weekend. My upper dash was slightly darker than the lower. Now its just a little bit lighter. I can't believe you could get the colors to match any better out of a spray can. I'm very happy with it. Time will tell how well it holds up. I did my entire upper dash including the passenger airbag cover and three vents as well as the two rear speaker grills. It took about 1 1/2 cans of paint and about the same for the low luster clear coat. I used dish soap and SEM Vinyl Prep and a lot of elbow grease. Cost about $70.00. Well worth the money.
Before
After
Mike my Local Upholstery shop carries it. They are in Lynwood. on Atlantic ave. Go to the sem website and you should find a local dealers list.Where did you buy the SEM paint & prep at, Stoney?
