Amazingly the plasigage is still pliable.
Time flys , I bought the inside- outside mics in 1973!!
One hole big ?they were all around 0.022-0.025 with one at 0.029 on cylinder 5.
It must matter somewhat, because (my understanding is) letting ring gaps line up is a known faux pas.Does ring gap really matter that much once you get above 1000RpM?
At 1000RpM, the piston goes from bottom to top in 31ms.
At 2000RpM, that number drops to 15ms, and so on.
Not much time for mixture to leak past the first ring, go around the piston to the second ring, then past the oil rings.
