Thanks for the help, my friend finally showed up who actually has some experience with shocks. This is my first car without struts, so my first time installing shocks myself.
We tightened it until the bushing was flush with the washer, which made the washer 1 3/8" from the top. I was using a big 22mm wrench which made it hard to gauge how hard I was tightening it. This is my second time installing them, a couple days ago I obviously didnt tighten the bolt enough.
You acess that bolt from a acess hole in the upper A arm right? Then a flange thing on the bottom of the stock with 2 bolts on the lower A arm?
Yeah, the top bolt is acessed through the top, real easy to get to with the wheel off. The two bottom bolts are on the lower arm and are in plain sight. Not sure what you mean by flange.
