·Okay...It all started with just a cam swap, now my edge 3000 is on the way with a transgo kit, now Iam reading about the line pressure vacuum control. For my street application is it needed? I will have the trans out when I do the t/c and transgo so it would be a perfect time to do it.
My setup will be XE230/236 cam, pocket ported heads, AS&M headers w/exports, borla exhaust, 3.73 gears, edge 3000 2.45 STR, Herter tune with 6000 shift points. Problem is all these mods are adding up on my budget cam swap!
One mod always leads to another!! Will my trans last longer if I spend another $90.00 on the vacuum mod?
Oh buy the way... I am not optimizing this car for drag strip usage, Yes I should have went with a smaller cam if daily driver was the goal but its the cam I got so its going in. I am willing to give up some 60ft and ET so thats why the lower shift points and stall rpm.
