Using one right now,and if one is crafty with factory connectors. The LS style MAF includes the IAT sensor in the same piece. Which is why there are five pins...
very cool so basically deleting the one in the intake elbow
for me the oem set up is fine
yeah....you need to pull that wire and pin it into the 4 pin connector that came with the new style MAF
with that said it is plug & play out of the box with the adapter that comes with it where you leave the IAT where it is
I see what you mean since the adapter they give you is making use of only 3 wires in which case the iat temp in plastic maf is not going to be used vs if you steal pin from old iat then add 4th wire to adapter now making use of the built in iat on plastic maf .
Am I understand you guys correctly ,?
Sent from my iPhone using Tapatalk
You'll need two more of the terminals w/wire that install where there isn't any in the new 5 circuit connector. Either splice,or using a conversion connector. into the two wires from the harness that plugged into the stock IAT...
