101 - 120 of 147 Posts
Discussion Starter · #101 · (Edited)
Make sure not to miss post #100 on the previous page!
Attempting to deliver power in a straight line
the red ratchet strap is temporarily retaining the angle of the tail shaft
Discussion Starter · #102 ·
So my POS 9C1 driver goes from 11MPG around town to a whopping 30+MPG highway.....
@ 365+ NA RWHP
part of the combo is K-Member belly pan and post rear axle belly pan
Looking for free power everywhere I can get it.
By managing all the parasitic losses and frictions
So here we go..
these little babies make the job easy!
When you have the fame tore down and 100% bare
it is super easy to filp it over
might as well break out the tap on the 0.120" wall frame
my pulse elevated when I saw this
Discussion Starter · #103 ·
previous post we put some M6 x1 threads tapped into the bottom of the frame.
this is what that was all for
ultra light aluminum M6 bolts with button heads make for a nice install
huge percentage of area with smooth air flow
so clean
Discussion Starter · #104 ·
Back to the basics,
Wheel Bearings and rotors.
installed
Discussion Starter · #105 ·
Been working my butt off on work / Datsun and some health issues
There is lots of progress to report
New pictures this weekend
Discussion Starter · #106 ·
In search of better fabrication speed
I liberated the shop Plasma Cutter from the fab area.
first it needed new tips
then
then it need an extension cord to make it from the plug to the Datsun
whole day side mission getting the plasma working
Discussion Starter · #107 · (Edited)
Need a hole to install this bolt in
also need an access hole in the Square tube!
since the 4x4" is .120+" thick it is a tough job by hand
Plasma is great.
It is like cutting metal with a Sharpie!
Just draw the line you wish slow and steady.
Using a pipe or tape roll as a template helps
Bamm! We have a Cab installed
Continued "astoundment-ness" at the build. Not much for any of us to retort on 'cept maybe is that tab stout enough to hold a cab on in a calamity....
And stay healthy eh.
Discussion Starter · #109 ·
i'll post the seat brackets soon,
you could pick the car up with them
Discussion Starter · #110 ·
Discussion Starter · #111 · (Edited)
Lots of Progress
DeathMobile has joind the TBT / Datsun crew.
Bringing labor and his insight to the table, progress has sped up.
Shawn your guilty... instigation and inspiration.
Progress,
-Hays Dragon Claw Clutch installed on motor
-trans installed on motor
-machup engine out of car
-LS7 / TR6060 combo installed in car
-clutch hydraulics functional
-throttle pedal functional
-WX3 wheels polished and powder coated
-brakes installed front
-brakes installed rear
-3rd gen IROC Camaro parking brake salvage yard acquired
-parking brake functional
-fire wall frame work built
-Savannah van hydro-boost and 9c1 brake rod and pedal fabed to work together
-pedal assm. sand blasted painted and re installed
-wiper motor sandblasted painted installed
-clutch and bleeder hose installed
-temp clutch rez installed and bleed
-new driver door handle installed and functional
Discussion Starter · #112 ·
Discussion Starter · #113 ·
She is already distracting!
Betty - 17' Cam6 2.0T A8 2LT RS HMB
Discussion Starter · #114 · (Edited)
Last week
-started cooling system hose run
-tied rear seat frame brace to 4Link package tray for Drive shaft carrier
-made temp drive shaft carrier bearing mount on new braces
*will use this structure for safety loop as well
This week,
-installed radiator
-ATI LS7 Under Driven / No AC / Dampener install with Pin
-find correct belt size
-install belt
-brake master and prop valve lines
**adapting 9C1 Prop valve and ABS to Savannah van HB Master Cylinder
*what a B!+c# / PIA
Discussion Starter · #115 · (Edited)
I must work quickly, there is so much to do, a vessel for Maxis, the staffs, the opening of the gateway.
Stay Tuned!!!!
Datsun 620 project has to drive before Datsun 6/20 day!!!!!
33 days and counting!!
Discussion Starter · #116 ·
Saturday time to thrash
spent the morning with El_Jefe_Vlogs
we ended up with an aborted dyno session due to burnt ign wires
*new video will be up in a day of this mornings session
Its now noon time to rock on the Datsun!
Discussion Starter · #117 ·
more progress
more updates
soon
Discussion Starter · #118 ·
33 Day thrash complete!
Drove my newly fabricated partially complete Datsun into the 6/20 car meet.
Discussion Starter · #120 ·
working on getting caught up online and in the real world
New clutch on the motor
The beginnings of the vision developing into reality
