That deserves an interpretation of the acronyms, and a description of the part itself.
It had almost sounded like you described the pushpins holding bumper fascias on, but wasn't sure.The original part was installed like a pop rivet. The center can be pushed out from the front/out side, and the fastener removed from the body panel. .....
More good points. I had thought of using those toy acorn speednuts, even with wings coming in from the backside. But. you see from the pics the weak link is the contact point chafing and stressed at the body metal, which makes anchoring the back part rather moot. They likely learned by now at Cady central to use a little more weather resistant plastic on applications so close to the ground. If I do a correct ID rubber grommet that protrudes less than that head I should be good.
Check. I honestly hadn't expected much airplay outside of the Cady forum - where this minutia is more familiar. Thanks checking for potential alternates. I recalled months ago deep cleaning my son's Altima there are plastic pushballs with similar sockets holding in the rear deck that I can hunt details on.Those pics would have helped in the beginning. .....
Just received.
