my 95 runs as if its on E even when tank is full i did plugs and wires some guy said check the fuel pump im lookin for a second opinoin plz all input would greatly appreciated
When was the fuel filter last changed? Check the fuel pressure. Then check the cat's.
Check the fuel pressure before you spring for a pump ! Filter would depend on miles/age/cheap gas. If the cats are falling apart then it can cause the car to run/feel like a 4000lbs bag 'o ****.
