T
i have a 95 ss ad when im driving my front end sounds like change when i hit a bump.has anyone ever had this problem before.pleae help me out
F
Two things to check - the end links for the front swaybar and the front end alignment shims. The "jingling change" or "rattling chain" sound from the front end is nothing new on the B-Bodies. The alignment shims are the most common culprit.
HTH :D
Mine did that too before I replaced the entire front end...the endlinks were tight and the shims were tight too...I think it was the lower balljoints...they were REALLY REALLY bad.
Sometimes if the brake pads are really lose in the caliper they will sound kinda like change rattling.
