I have been researching this for some time and there is tons of info on other forums but not much on here. I learned a lot at sounddeadenershowdown.com. Fuzzcar has also been a big help from here.
So far I have ordered 120 square foot of Second Skins Damplifier Pro from here. I plan on using this on the doors, floors, roof, and trunk.
I am still researching and looking for input on what I will put down over the entire car for a spray on or brush on sound deadner.
After both those I will put down a layer of closed cell foam with a layer of radiant barrier attached on each side of it. Sourced 100 square foot of that from ebay here. Plan is to put this on the doors, floors, roof, and trunk. This will help with heating/cooling, add some sound deadening, and act as a decoupler for the final layer of mass loaded vinyl (MLV).
The final layer of MLV will be put on the doors, floors, and trunk. I sourced 100 square foot of that off Ebay as well here. Still need to find a glue or tape for the seams of this.
So to start the project off I gutted the interior and trunk. Had a couple spots of surface rust that I ground off and hit with some POR 15. Got a little out of hand with that stuff and ended up coating most of the floor and trunk with it. Let me know if you guys have any input or ideas. Will be updating as supplies come in and time allows for install.
