All from LeadSSled - reposted to make sure the cache file listed above isn't lost..
Spark Plug Reference
I saw this posted on another forum and thought that it might be helpful to post it here. This may be "sticky" material.
This is taken from Nitroustech.com and I've seen the same thing on many many forums. Figured we could have this here for everyone to use.
**Note: Heat ranges are determined by NGK standards. Not all plug manufacturers follow the same guidelines.
***Note: List is intended for reference only. Please consult with head mfg. and ignition mfg. for proper gap.
****Note: NGK IX and Denso plugs are Iridium.
LT1
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .050
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Champion RS14YC6 (stock number 13); Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
LT1 w/ AFR heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations
Heat Range: 9
Gap: Consult ignition mfg.
Plug: NGK 5672A-9 (stock number 7405); Autolite AR3910; Champion C59YC (stock number 792); Denso IQ27 (stock number 5315); Denso IQ01-27 (stock number 5708)(diagonal platinum ground); Denso IQ02-27 (stock number 5711)(horizontal platinum ground)
Heat Range: 10
Plug: NGK 5672A-10 (stock number 7942); Autolite AR50; Denso IQ31 (stock number 5323)
Heat Range: 11
Plug: Denso IQ34 (stock number 5324)
LT1 w/ Trick Flow & Edelbrock Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations: approx under 9:1 compression
Heat Range: 4
Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
MFG Recommendations: approx 10.5:1 compression
Heat Range: 5
Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
**NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly.
__________________
Added from tbsimmons...
Just to add a few more.
The AR Autolites are about the same from what I see at the normal ones.
AR3910 and 3910. The difference is the ground strap is cut back. Save some dough and di it yourself.
Also the 3923 is about the same heat range as a 3911, 3922 - 3910 if you guys want a resistor plug.
__________________
Troy Simmons
FASST - ROD - ISSCA
CPT Full Manual 700R4
Big Stall Big Gear
Does anyone know if someone makes a shorty, header-style plug for the LT1 heads?
hey thanks. I didn't know how to post it like that.
