Ok two part problem.
First I am not getting any audio for passenger rear speaker.
I even hooked up up spare speaker to connection at passenger front kick panel and am not getting signal there.
Second problem passenger front speaker blown.
Just want to know a good speaker to go with for replacement. I plan to put in a double din/system in few months so like to take front doors off just the one time to replace speakers.
Try disconnecting the blown pass front speaker, if the voice coil is shorted it could be putting the head units internal a,pilfer into protect, thus the rear speaker output not working. Some head units have a separate left and right internal amp, this might be the case on yours: left side working but right side not due to the blown speaker. Let us know how you make out.
I use Memphis in all my setups, but go to a local shop you know or a friend recommends and listen to as many speakers as you can and decide what you like that is in your budget.
