1 - 20 of 22 Posts
trying to find out if i have any thing that a normal 91 5.0 classic wouldnt have any info helps
AA7 Window, Power Operated, Quick Opening
AG1 ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2 ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AG3 ADJUSTER, FRT ST, POWER, 6 WAY, 2 POSITION MEMORY
AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AM6 SEAT, FRT SPLIT, 3 PASS, CTR ARM REST
AU0 LOCK CONTROL, REM0TE ENTRY
AU3 LOCK CONTROL, SIDE DR, ELEC
A90 Lock, Rear Compartment Lid, Remote Control, Electric
BA1 ORNAMENTATION, EXTR HOOD
BC1 Ornamentation, Interior, VP
BY1 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
B18 Ornamentation, Interior, Deluxe
B37 Covering Floor Mats, Front and Rear Auxiliary
B4U PERFORMANCE PACKAGE, SPORT
CD2 INDICATOR, WSWA JAR FLUID
C49 Defogger, Rear Window Electric
C60 HVAC System, Air Conditioner, Front Manual Control
C71 Lamp, Interior, Front Door Courtesy
DD1 MIRROR I/S, R/V TILT, DUAL READING LAMPS, COMPASS
DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
D4L GEAR, SPEEDO DRIVEN (D4L)
D64 Mirror, Visor Vanity Illuminated, Passenger Side
D8I SENSOR, VEH SPD (D8I)
D85 STRIPE, B0DY SIDE LOWER ACCENT
GU5 AXLE REAR, 3.23 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
JA2 Brakes,Heavy-Duty Disc Drum
JM4 Brake System, Power, Front Disc, Rear Drum, Antilock, Front and Rear Wheel
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K60 GENERATOR, 100 AMP
L03 ENGINE, GAS, 8 CYL 5.OL TBI
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO Transmission, Auto O/D
NA5 Federal Emission System
NK4 STEERING WHEEL, SPORT LEATHER
N33 STEERING COLUMN, TILT TYPE
N65 Wheel and Tire, Spare, Space Saver
PA5 HUBCAPS, WHEEL
QQG TIRE ALL, P235/70R15 BL R/PE ST TL AL3 102V
T82 Cluster, Instrument, Cool Temperatue
T87 LAMP, CORNERING
UQ4 SPEAKER SYSTEM, BOSE, 4
UR5 INDICATOR, LOW ENGINE OIL
UW1 DIAGNOSTIC SYSTEM
U11 Cluster, Instrument, Police, Certified Speedometer
U38 INDICATOR, LOW COOLANT
U75 ANTENNA, POWER, RADIO
VK3 License Plate Front Mounting Package
VO8 Cooling System, Heavy Duty VIF Paint, Special Metallic, Charge
V73 VEHICLE STATEMENT USA/CANADA
Z09 MODEL CONVERSION, CAPRICE CLASSIC
20C TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (C) (91)
20I INTERIOR TRIM, VERY DK SAPPHIRE (91)
209 SEAT BELT, COLOR VERY DK SAPPHIRE (91)
29A STRIPE COLOR, ACCENT, MED BLUE (91)
40U PRIMARY COLOR, EXTERIOR, WHITE (91)
41Q MOLDING COLOR - BLACK (91)
6TM Spring - Computer Selected, FRT, LH
7B3 SUSPENSION SYSTEM, SPECIAL HANDLING
7TM Spring - Computer Selected, FRT, RH
8HJ COMPONENT RR LH - COMPUTER SEL SUSP (8HJ
9HJ COMPONENT RR RH - COMPUTER SEL SUSP (9HJ)
T
There's SO many options for these cars that almost any combination is possible.
The only unusual thing I see is a Certified Speedometer in a non-9C1 car. Other than that it looks pretty common.
V
You don't see a ton of G80 cars that are civilian 305s, either. Pretty uncommon.
i was thinking that these would be rare for the 5.0 :confused:
V
You don't see them every day, but what's weird about it having a 700R4? That should be the ONLY thing it would have.
oh ok i didnt know about the trans.. do you guys think that any of the codes would make it worth more then a 91 5.0 you see every day im not looking to sell it right now but down the road i want to sell this and get a SS :D thanks for the input so far
Unfortunately, I don't think anything on it makes it any more valuable than any others without the options. Here's what I look at, pretty much in order:
Model year
Engine
Miles
Condition
The rest of it may be a small perk to owning the car, but it's still a '91 with a 305 in my book.
K
It's an LTZ.
It has 7B3, B4U, Z09, GU5, G80, and U11. It also has V-rated tires (QQG, also see door jamb sticker). LTZs were pretty rare as compared to standard Caprices.
:confused: :confused: are you sure about the ltz wouldnt have some ltz scrips on it or some thing?? :confused: :confused: i have this car for over 6 months and havent seen one thing saying ltz thats why i ask PLEASE HELP thanks guys
V
:confused: :confused: are you sure about the ltz...
I believe he's right. That may make things a little better, but it's not the Holy Grail or anything.
how can i tell if it is or not car fax and title say caprice classic is it just a package or some thing
K
Discussion Starter #13
When someone buys (or rather bought) an Impala SS, the same exact thing occurs.... the car will be listed as a Caprice.
Because.... the Impala SS is juts a trim package applied to a Caprice. Technically, so is the 9C1 police package. And ditto for the LTZ. They're all trim packages that involve a bit more than just cosmetic trim features.
In your case, the use of the U11 certified cluster is the most key tell-tale. That cluster wasn't an option your could just order, and it's not just an easy thing for a dealer to install (it's not plug-n-play, I know because I've done 1.5 such swaps). The cluster was ordered with the car, that's why it's listed on the SPID.
To get the U11 you had to either get a 9C1 package (which would then automatically include the U11 cluster), or you had to order an LTZ Caprice (which again would automatically get you the U11 cluster).
What you need to get is pixs and documents on the 1991 Caprice (like a factory brochure), as well as the road tests done on the car. The 1991 Caprice LTZ was Motor Trend's Car of the Year so that might have enough pictures. It would also show you whether there were any LTZ badges affixed to the interior or exterior.
I'll add, finally, that the ONLY B platform cars I have ever seen with the LTZ badge affixed to the front fender (between the wheel and the door) was on the 1993 models. The 91 and 92 models didn't get the LTZ emblems, and I don't think there were interior emblems either.... at least from the 91 LTZ that I once rode in. My buddy & I were able to "tell" that it was a non-std Caprice by the stance of the car as we drove by the used car lot --- so we pulled in to investigate. The stance was taller because the copcar springs were used (another telltale I forgot to mention). We looked under the hood, in the trunk (instant SPID decode!) and drove the car. IIRC there were no LTZ emblems or badges.
The GM Bcar Parts & Illustration book(s) would also show what years had the LTZ badging if you could coax someone to look. HTH.
Discussion Starter #14
thanks for your help kdrolt i really appreciate it
Discussion Starter #15
What year LTZ had the flat-style hood ornament?
7o7, does yours have the stand-up hood ornament, or flat-style?
Discussion Starter #16
Just curious, where did you find a list of descriptions for your RPO codes?
K
Discussion Starter #18
Good question -- I forgot that one. The flat hood ornament is the one listed in the SPID above as BA1 ORNAMENTATION, EXTR HOOD
That "flat" ornament was only used on the LTZ.
EDIT:
Other relevant threads:
http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=12;t=003454
http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=6;t=001454#000009
BA1 is the flat ornament, and I believe it was used on all 91-93 LTZs. The T52 is, I think the fender emblem I mentioned somewhere above that was only used on 93 LTZ.... IIRC. HTH.
Discussion Starter #19
There should be a LTZ nameplate on the dash to the right of the radio where the coin holder on a 9C1 would be.
Chris
Discussion Starter #20
i dont have the flat hood i have the stand up and no name plates any place thats why im so lost :confused:
1 - 20 of 22 Posts
