I just finished R&Ring the axle bearings and seals on my 96 9C1. After I installed each axle, and c-clip, I rotated one of the axles to gain access to the pin which goes thru the carrier.
After doing so the spider gears are no longer aligned perfectly with the pin hole.
-How do I get the spider gears to walk so I can get the pin back in the carrier?
This is on an eaton posi carrier & gears I purchased from Dan @ C.I.A.
I spoke with Dan and he referred me to Randy's Ring & Pinion. I wasn't able to get a hold of a live tech guy and left a message for them.
I was hoping someone here might be able to help out.
Thanks!
Thanks!
