I just put hotchkis lowering springs on two weeks ago I have given them time to settle and now the front passenger is sitting a 1/2 inch lower than the driver side I am about to go crazy.. I put new shock on and everything WTF...... Someone help.. Befor I loose my mind
check for proper rotation of all springs they have pocket/slots they slip into. Rears top pig tail center sections points to the drivers side on both sides. And front dont know witch i just rotated them till the slipped into place.
On the fronts, I just made sure the tail of the spring was located per the FSM. There are two inspection holes. One should be covered and the other should be visible or at least partly visible. On the top of the spring, it's just a matter of making sure it's seated properly in the pocket.
