1 - 10 of 10 Posts
Hi Guys,
What are the actual spring rating numbers for:
1) Our Stock Springs Front
2) Rear
3)Hotchkis Front
4)Rear
I am assuming they come in pounds/inch?
I have a 95 SS.
Thanks Stretch
Spring Rates
</font>
  • Stock SS Springs
    Front: 444 lb/in
    Rear: 154 lb/in</font>
  • Hotchkis
    Front: 500 lb/in initial, 630 lb/in final
    Rear: 180 lb/in initial, 240 lb/in final</font>
  • Eibach
    Front: 588 lb/in (linear)
    Rear: 143 lb/in initial, 228 lb/in final</font>
  • Global West
    Front: 750 lb/in</font>
  • Hypercoils
    Front: 350 lb/in – 629lb/in working range 500 lb/in – 629 lb/in
    Rear: 120 lb/in – 224 lb/in working range 180 lb/in – 224 lb/in</font>
  • Sprint Springs
    Front: 485 lb/in
    Rear: 285 lb/in</font>
  • ST
    Front: 533lb/in.
    Rear: 272lb/in.</font>
R
What about Intrax? The softer the spring rate the softer the ride right?
K
Hey Bad Rod, any idea where the 9C1 springs fit in there?
kevan, I am not sure about 9C1 springs. I would like to know myself!
Thought I would bring this back up to see if anyone else needs to know any info or would post any more ratings
TTT
L
From somewhere deep in the annals of the forum...
9c1 Springs
Front:
Uncircumsized = 440 lb/in
After Briss to SS Height (3/4 coil) about 500-525 lb/in
Rear:
New = 160 lb/in
Old calculated at 184 lb/in
1 - 10 of 10 Posts
