1995 RMS with 17" SS wheels, not sure which size tire I will use, probably stock.
Front springs Moog 5552 w/ Koni 8040 1087
Rear GM 482086 ( 1991 9C1) w/ Bilstein 24-009294
Will this work? Is there a better front option?
Goals: need ground clearance for rough roads, want a sporty ride not the mushy gushy FE1.
I will be upgrading brakes and bars too.
Any suggestions or help with recommendations is much appreciated.
I prefer new springs without any cutting.
Thanks, Walt
I went with factory rate Bilstein and these springs:
Moog 7268 Front Ford 150 97-03 Dodge Van 79-80 750Lbs
Moog 5419 Rear Caprice 79-96 (9C1?) 173Lbs
Front springs Moog 5552 are 543Lbs
You post the moog equivalent for the rears
I do not think you would notice much difference with your choice. The 750Lbs firm up the handling and are a little higher than factory.(0.16")
I would stick to one shock manufacturer or get adjustable ones. I would be afraid different design targets of different shock companies could do weird things.
The forum search may help you or try searching from outside and include Impala forum. I went through old posts one at a time before I bought my springs.
This is one of those posts:
https://www.impalassforum.com/vBulletin/17-suspension/263287-gm-spicer-88913497-750-lb-inch-springs.html
