1 - 20 of 54 Posts
Lowering Springs
First some information about the stock Springs/Suspension components.
There were Basically 4 types of springs used on the Caprice, Roadmaster, Fleetwood, & Impala SS sedans.
"FE1", The standard, soft springs. Which are notrious for sagging(certainly so on Roadmasters). They are considered floaty, and mushy by many. These suspensions also came with a small 28mm front sway bar, and no rear sway bar. They also came with rather mushy shocks.
"FE2", "F40", and ***(police RPO), The heavy duty suspension used on cars with the towing package, HD suspension package, or the "Fleet" cars, such as a livery R1P Fleetwood, or a Police 9C1/9C3 Caprice. A Taxi 9C6 Caprice. FE2/F40 were used on the tow pack cars, or the Livery Fleetwoods. Where as *** was used on the police cars. These springs are much stiffer, and tend to have a ride hieght that is higher than FE1 springs, or the Impala SS springs. There were slight load rating differences, such as the FE2 springs are one "step" stiffer than the 9C1 springs on GMs chart. These cars also got the large 30mm front sway bar, 26mm rear sway bar, and stiffer shocks. Some 9C1's had optional Bilstiens. The bushings int he control arms mat be stiffer. The body bushings are likely stiffer as well. These springs definatly ride a little stiffer than FE1 springs, but are not objectionaly stiff.
"FE4", the hd, sporty suspension on the Impala SS. Basically the same as a FE2, F40, 9C1 suspension, but the springs had a lowered ride height(more later, when I collect more info)
Wagons Info on wagons to come.
Aftermarket Springs
*Note: Drop is listed Front/Rear. These are sets. 2 fronts, 2 rears. Unless noted!!!
Vogtland: $225
http://www.vogtland-na.com/sportsprings.asp
http://www.powerperformancemotorspor...productId=1791
Suspension Techniques "ST": $250
http://www.stracing.com/speedbars.html
http://store.summitracing.com/partde...5&autoview=sku
2"/2"(not sure from where)
Hotchkis: $275
http://www.hotchkis.net/9496_impala_...l_springs.html
http://www.powerperformancemotorspor...productId=1734
Caprice, 1.5/1.25. Impala SS, 1.25/1.0, Progressive
Eibach:
http://eibach.com/cgi-bin/htmlos.exe...02072200004189
Impala SS, 1.2"/1.0"
Eibach: $270
http://eibach.com/cgi-bin/htmlos.exe...11819800004189
Caprice, 1.2"/1.2", Progressive.
Sprint: $310
http://www.sprintspring.com/p-70-car...nsion-kit.aspx
Caprice/Impala SS, 2.0/3.0,
Springs, Sold in pairs.
Global West: $140 - Fronts Only!
http://www.globalwest.net/IMPALA-SS_...NENETS_INC.htm
http://www.jegs.com/i/Global+West/459/S-81/10002/-1
Linear Rate, slight drop over Impala SS, Stiffer than stock.
Rustic Racing: $145 -Fronts only!
http://www.rusticracing.com/Springs/index.htm
Linear rate, Drop(check site), much stiffer than stock. 2 different stiffness available.
Rustic Racing: $495 - Rear Coilover kit!
http://www.rusticracing.com/Race/RearCoilOver.htm
QA1 Springs: $500-$700 - Rear Coilover kit!
http://www.umiperformance.com/produc...category_id=82
Shocks​
Did I get it right now?
*Note, Shocks are listed for the price each.
Monroe Senasatracs
Monroe Severe Service
Generally Considered the "Poor Mans Bilstiens". A very stiff, and overbuilt shock. Much heavier than standard Monroe shocks. Have shown very respectable results for a more inexpensive alternative to the higher end Bilstiens. I have used these on 5 cars now, and they are very nice for the price. On an FE1 car, they do make the ride firmer, which many consider a good thing, I sure do. On the FE2/9C1 cars, these shocks are not overly firm in my experience. I really like the way they ride, and the improvement over worn out stockers. These are much stiffer than the typical Sensatracs. Some that have used these, and the bilsteins say you will know these shocks are there. They are a bit rougher than the bilstiens, and may even be a bit stiffer. Or atleast seam stiffer. But also that, the bilstiens do there job, and do it a little more un noticed.
Front
http://catalog.monroe.com/monroe/pro...catalog=MONROE
550012, lifetime warranty
Rear
550013, lifetime warranty
Rear, Load Leveler:
550052, lifetime warranty. this has a helper spring on the otherwise 550013 shock.
Bilstein, "stiff", Sport shocks
These were originally intended for the 80's-1990 Caprices. They are considered to be stiffer than the Heavy Duty shocks.
Front
http://www.bilstein.com/mistore/prod...pany_id=100484
1104
Rear
0929
Bilstein, "Soft", Heavy Duty
These were originally intended for the 91-96 Caprices. They are considered to be softer than the Sport shocks. Many places claim the Sports to work better with the stock springs.
Front
1516
Rear
1517
Edelbrock IAS,
I know that a few members here have used them, and liked them. I have no info on how they compare the the Coveted Bilsteins.
Front: $85
http://www.edelbrock.com/automotive_...ocks/car.shtml
3379, listed for 71-96 Cars
Rear: $85
3479, listed for 91-96 Cars
Rear: $85
34030. Listed for 71-90 Cars, these will fit, not sure of the difference in valving?
Hotckhis HPS 1000, revalved Bilstiens.
I would have to assume these would be stiffer than stock bilstiens, but I have no data on this. Bilstein will revalve a shock for $45 each, last I checked. Thats an option if you have some old Bilsteins.
Front $110
http://www.hotchkis.net/front_hps_10...781_fbody.html
http://www.powerperformancemotorspor...productId=1742
70010009
Rear $90
http://www.hotchkis.net/rear_hps_100..._agb_body.html
http://www.powerperformancemotorspor...productId=1743
71010009
Koni, single Adjustable
Front $110
http://www.koni-na.com/cat_search.cf...&submit=Search
http://www.powerperformancemotorspor...productId=1793
8040 1087, remove to compress & turn to adjust
Rear $110
http://www.powerperformancemotorspor...productId=1794
8040 1088, remove to compress & turn to adjust
QA1, single Adjustable
Front $150
http://qa1.thomasnet.com/item/chevro...=prod&filter=0
http://www.umiperformance.com/produc...em_id=88895205
TC1958P, knob adjustable, 12 settings
Rear $150
http://qa1.thomasnet.com/item/chevr...?&plpver=1001&origin=advsrch&by=prod&filter=0
http://www.umiperformance.com/produc...em_id=88895206
TC1661P, knob adjustable, 12 settings
QA1, Double Adjustable
Front $330
DTC1958P, knob adjustable. Independant compression / rebound adjustment.
Rear $330
TC1661P, knob adjustable. Independant compression / rebound adjustment.
Control Arms - Rears
Lowers
*Note, these may not be the Cheapest prices. Or the only place to get them. I tried to use the Factory site, and a place to order them if the Factory does not sell the directly. Or If the factory charges alot over other places you can find them.
The Stock Rear Control Arms, are stamped steel, with rubber bushings. Both the Lower Control Arms (LCA), and Upper Control Arms (UCA). The stock arms are cheap, and when held in your hand, you can actually flex them in a twisting motion. Also, the rubber bushings offer lots of flex, and isolate road vibrations from the frame. This gives a quiet, and smooth ride. Which is great for your average driver. But when you attmept to put high torque amounts to the ground, or go around a corner fast... Guess what? They Flex all over the place.
While drag racing, this can create wheel hop, and axle wrap. Same with cornering. Also with cornering, if you want to put a bigger sway bar on the rear, the stock arms just are not up for that kind of abuse.
It is debatable if Poly Bushing at both ends in the LCA is a good idea, due to suspension bind. But it is generally accepted that Poly bushings at both ends on the UCA will cause bind, and wear the bushings out in street use. This is why Many places offer LCA's, and UCA's with "Rod ends", which allow a twisting flex, but not a front to back flex.
Another cosmetic issue, is that when GM opened the wheel wells from the 91/92 Caprice, it left the wheel sitting off center of the opening. Sitting slightly too far forward. The problem is the body, not the suspension. But pushing the axle back via the suspension is cheaper and easier. there are Many extended LCA options. When you extend the LCA's, you need to extend the UCA's as well, in order to keep a proper pinion angle.
I hope this helps your Control arms choice.
Lower Control Arms, Rear - Stock Length & Adjustable Length
AcDelco: $50
http://www.gmpartsdirect.com/results...umber=10289786
Stock GM replacement. Stamped Steel C channel, rubber bushings. These are the late style arms, that were part of a TSB. These would be the BARE minimum for using a STOCK rear sway bar. Comes with hardware. Definatly would be better than the 13+ year old stock units, or attempting to use a 91-95 Sway Bar mounting style. The Early Style mounting had cracked a few arms according to GM. The Early style arms don't have the holes in the top to use the Later Style mount hardware. An aftermarket Sway bar will Rip these apart. Please don't attempt it!
Spohn Performance: $180
http://www.spohn.net/shop/1978-1996-...-Bushings.html
Fixed, Poly Bushings, Greasable
UMI Performance: $190
http://www.umiperformance.com/3615?category_id=25
Fixed, Poly Bushings, Greasable. UMI may offer forum members a discount, since they are a forum vendor.
BMR Fabrication
: $210
http://www.bmrfabrication.com/ImpalaSS.htm
Metco Motorsports: $270
http://www.metcomotorsports.com/proddetail.asp?pro d=MCA0001&cat=112
Fixed, Billet Aluminum,Poly Bushings, Greasable
Hotchkis: $290
http://www.hotchkis.net/7896_gm_bbod...ling_arms.html
http://www.powerperformancemotorspor...productId=1740
Global West Suspensions: $300
http://www.jegs.com/i/Global+West/459/TBC-12/10002/-1
Fixed, Del-a-lum Bushings & Rod Ends, Greasable.
*Note: Whats interesting to note, is that GWS suggests the use of STOCK upper control arms in order to not bind while articulating.
Rustic Racing: $350
http://www.rusticracing.com/Rear_Arms/index.htm
Adjustable, Poly Bushings & Rod Ends, Greasable. These are made by Currie. Curries site doesn't reflect this, but if you call them you can get a set. Unless Rustic pulls there act together, I would call Currie and skip Rustic.
Lower Control Arms, Rear - Extended Length & Adjustable Length
Spohn Performance
: $180
http://www.spohn.net/shop/1978-1996-...ed-Length.html
Extended 3/4", Fixed, Poly Bushings, Greasable
UMI Performance: $200
http://www.umiperformance.com/3612?category_id=172
Extended 5/8", Adjustable, Poly Bushings, Greasable.
UMI Performance: $210
http://www.umiperformance.com/3614?category_id=172
Extended 5/8", Adjustable, Poly Bushings & Rod Ends, Greasable.
BMR Fabrication: $210
Extended 3/4", Fixed, Poly Bushings, Greasable,
BMR Fabrication: $260
Extended 3/4", Billet Aluminum, Fixed, Poly Bushings, Greasable,
Discussion Starter · #4 · (Edited)
Uppers
Upper Control Arms, Rear - Stock Length & Adjustable
Spohn Performance: $110
Stock, Fixed, Ploy Bushings, Greasable
Spohn Performance: $170
http://www.spohn.net/shop/1978-1996-...djustable.html
Stock, Adjustable, Ploy Bushings, Greasable
UMI Performance: $115
http://www.umiperformance.com/3616?category_id=26
Stock, Fixed, Poly Bushings, Greasable
BMR Fabrication: $150
BMR Fabrication: $230
Stock, Adjustable, Poly Bushings, Greasable
Hotchkis: $230
http://www.hotchkis.net/7896_gm_bbod...iling_arm.html
http://www.powerperformancemotorspor...productId=1737
Metco Motorsports: $325
http://www.metcomotorsports.com/prod...p?prod=MUC0001
Rustic Racing: $325
Upper Control Arms, Rear - Extended Length & Adjustable Length
Extended, Poly Bushings, Greasable
Extended, Adjustable, Poly Bushings, Greasable
Extended 3/4", Adjustable, Poly Bushings, Greasable
UMI Performance: $170
http://www.umiperformance.com/3618?category_id=26
http://www.umiperformance.com/3617?category_id=26
Discussion Starter · #5 · (Edited)
Sway bars
Front Sway Bars
BMR Fabrication: $190
1.25"(1 1/4" / 32mm), Solid, B-body Style, and 2nd Gen F-body Style available. Not Suggested for Lowered use?
Spohn Performance: $200
http://www.spohn.net/shop/1978-1996-...rome-Moly.html
1.3125" (1 5/16"), Solid, B-body Style,
Hotchkis: $325
http://www.hotchkis.net/7896_gm_bbod...bar_sedan.html
1.4375" (1 7/16"), Hollow, B-body Style.
Rear Sway Bars
Spohn Performance: $230
1.5", Solid, Straight Style.
Hotchkis: $300
1.375" (1 3/8"), Hollow, Bent style.
http://www.neverenoughauto.com/index.php?target=products&product_id=5061
http://www.impalassforum.com/vBulletin/showthread.php?p=2173697#post2173697
Other Parts
Aift Bag, helper springs. "Drag Bags"
Airlift 1000's
*Note Airlifts are stuck inside of the rear coil springs. They cam be used to increase the load carry ability of the rear, raise a sagging rear, & stiffen the rear. They can also be used as a suspension tunning tool for drag racing launches. You can run the air lines so you can fill them independantly. Typically, the passengers side requires about 10PSI more to even things out on the launch.
Stock Springs. $80
http://www.airliftcompany.com/online_catalog.html
60755. For use with all stock springs, except the Impala SS springs.
Impala SS Springs. $80
60786. For use with stock Impala SS springs.
Lowering Springs. $80
60798. For use with Springs: Hotchkis,
Hotchkis $110
http://www.hotchkis.net/air_bag_kit_1922_only.html
http://www.powerperformancemotorspor...productId=1741
60798. These are "Hotchkis" air bags. Pretty sure they are just airlift 1000's with the price jacked up.
Instant Center Brackets
* Note These lower your "instant center", to improve the force put on the rear tires.
UMI Performance: $70
http://www.umiperformance.com/produc...em_id=88895322
Weld on.
Metco Motorsports: $90
http://www.metcomotorsports.com/prod...p?prod=MIC0001
Weld on.
Drive Shaft Safety Loop
* Note. A good idea if you plan on drag racing, and launching hard. These will catch the Drive shaft in the event it snaps at the U-joint.
http://www.umiperformance.com/3625?category_id=176
Steel, bolt on.
Clear Image: $75
http://www.clearimageautomotive.com/Driveshaft S afety%20Loop.htm
Aluminum, bolt on.
http://www.metcomotorsports.com/prod...DL1000&cat=112
Steel, bolt on.
Anti Roll Bar (Drag Racing).
Tubular Trans Crossmember
Discussion Starter · #8 · (Edited)
Tech & ISSF Forum Vendors
Vendors
Power Performance Motorsports
http://www.powerperformancemotorspor...?categoryId=19
Control Arms, shocks, springs, front end rebuild parts, etc.
UMI Performance
http://www.umiperformance.com/bbody
Control Arms, shocks, IC brackets, Driveshaft loops, Rear coil overs
Clear Image Automotive.
http://www.clearimageautomotive.com/Products.htm
Control arms, shocks, springs, driveshaft loops
Tech Articles
Springs
Lowered cars pics.
http://www.impalassforum.com/vBullet...d.php?t=129235
Front Spring Install
http://www.impalassforum.com/vBulletin/showthread.php?t=235494
Shocks
Here is a good read on the Bilstien shocks.
http://www.theherd.com/articles/bshocks.html
Rear shock upper bolts: EZ change bolts
http://www.impalassforum.com/vBulletin/showthread.php?t=235505
Sway bars
Here is a good read on Sway Bars for these cars.
http://temp.corvetteforum.net/c4/vad...bardesign.html
Anti-Roll bar(drag racing)
http://www.impalassforum.com/vBulletin/showthread.php?t=233318
Control Arms
Box your own arms & Sedan rear bar on a Wagon
http://www.impalassforum.com/vBulletin/showthread.php?t=232510
Steering
PS fluid flush
http://www.impalassforum.com/vBulletin/showthread.php?t=234925
Body Mount system
http://www.impalassforum.com/vBulletin/showthread.php?t=228460
Discussion Starter · #13 ·
post for room. V
This is why you make a back-up Copy of important things. Took me 3 minutes to repost info that took me 2 weeks to collect, and organize.
Sticky!
sticky needed!!!!!!!!!!!!!
1996 Caprice 9c1, 2018 Ram Laramie CC 4x4 EcoDiesel , '03 Ram 3500 Laramie Sport QC 4x4 Cummins
I either didn't see it or you overlooked the FE3 sport suspension.:)
post for room. V
i had u covered even if you didnt, i wonder if they could merge my post into urs so there is no dbl info.
1 - 20 of 54 Posts
