R
Hey guys, this is my first time on here....this is awsome. Anyways, im wondering if ImpalaSS front and rear springs will fit into my 1979 Pontiac Parisienne with no problems. I'd like to drop the car only and inch or two from stock, so i was wondering if stock ImpalaSS springs will do that or if I need aftermarket. Any help would be appreciated. Thanks
I know that they would fit, and I believe you would get close to the desired drop. You should be able to find a set pretty cheap from someone that has upgraded.
They'll work fine. I got rear springs from an SS in my '83 Delta beater, though with a full tank of gas the rear sags a little.
