·Recently (started last month) my front end makes a bad noise from the front end on the drivers side when going over bumps. You can even hear it while driving 70 down the interstate and hit a dip or a mound. I had cut the front coil springs 2/3 coil when I did the lower ball joints and I think one of the isolators may have been partially in when I put it back together. I did this earlier this year and it didn't make this noise then. Last week as I was jacking it up to see if I could find the source ut did it then but I couldn't pinpoint it. My ? is well what could it be? Is it the shock? It seems to be happening only on the A arms moving downward stroke. Could it be the missing isolator?
