·What is the general consensus of people who have upgraded to the braided brake lines.
Was it worth it? Could you feel or measure any improvement?
You make a valid point. In light of the fact that I replaced several things at once, it would be difficult to state and pinpoint exactly how much was gained. The condition of my system was fair to average. Nothing was leaking hoses. The overall condition of the rubber hoses was decent. No bulges, cracks etc.. Thanks.Originally posted by Navy Lifer:
Dropped, it was the right thing to do for your project and it turned out well for you. I don't have any data to prove one way or the other, I'll admit--just a hunch more than anything else--all I want to be understood is that so many things were changed on your brake system at the same time, that it's not possible to attribute what the pedal feels like now strictly to the new hoses, since what it felt like before the work was done was going to change based on a number of things you did, in all likelihood. What was the condition of the brake components you replaced?
.....As far as being able to feel it, if the rubber hoses are in good condition and brakes are well bled, I think it will be difficult to tell the difference......
Originally posted by sherlock9c1:
FWIW, most of the improvement you may notice will come from the fact that you are replacing TEN YEAR OLD rubber lines with stainless......
As Bill alluded to earlier; new vs new.....you won't see any substantial difference in the performance of rubber vs steel lines.Originally posted by Dropped Fullsize:
Doesn't it stand to reason that stainless steel hoses will expand less than rubber hoses under brake pressure?.....
I didn't see these remarks earlierOriginally posted by Raxstone:
.....As for functional difference. As Navy Lifer already mentioned, you won't notice any. That is assuming your rubber lines are in good condition. The real benefit to the braided lines is in durability. You'll almost never have to worry about the rubber line breaking down....
