Looking forward to seeing what you're up to
The hubcaps are basically done, but need a little refining. The surfaces need a coat of resin, and sanding to smooth. I have the mounts pretty much made as well. The mounts will be glued inside the rim, and the caps themselves will have Dzus fasteners to hold them on. I must make a hole for the valve to fill the tires. Details are a PITA.You've been messing with the hubcaps for a while now, I'm guessing you finally got the right setup.
I do not have the room to store them. I would have to get the car on them as well, and that is not a possibility right now.Build some wheel cribs, just so worth it without having a lift to work under the car freely.
Got any pics of the starship? I just see the one on the profile pic.
I just started looking for a good block. I have everything to rebuild it except for the block, and maybe the crank.
