95 SS. When I first try to start the car, I can crank the engine for forever and it will not start. But if I just stop cranking and try again it will start right up. Anybody know what could be the problem.
Try this next time it has sat for a while, turn the key on, listen for the pump, when it stops, turn the key off......wait a few seconds and turn it back on again, then off after the pump stops in 2 - 3 seconds, now try to start it, if it fires right up then the problem is probably the ani-drain back valve in the pump, only fix is a new pump, mine lasted almost 2 yrs before the pump quit.
