1 - 1 of 1 Posts
Hello, I have a 94 caprice. LT1. The other day I got up and it would not start. It would just crank over and over and smell like gas. it was raining that day but I have never had an issue with starting or anything before. I changed the plugs (They were bad) went to start the car. same result. I came home today and tried starting it and it wanted to crank over and run. so I hit the gas to the floor and it sputtered and started. I drove it up and down the road. ran fine. until I pulled into the driveway I noticed the headlights/gauges were flickering and I was hearing a weird light tapping sound from under the hood. It did not sound mechanical though. Im not sure if its the Opti. or the Coil/Module or wires could be a factor. This is my daily driver and help would greatly be appreciated. Thank you
1 - 1 of 1 Posts
