Leaking water pump dripping on the belt making it slip.
Bad power steering pump.
I believe its the water pump making it slip because i changed the waterpump and i forgot to put plumbers tape on the thread so it leaked pretty bad on the belt...what steps should take to fix this problem?im gonna put plumbers tape on the water pump so what should i do after that?
10-4
You need plumbers tape for the threads of the fan/wp sensor that screws into the front of the water pump.
Just watch the weep hole for leaking after you fix that problem. Leaking weep hole means the water pump is going bad and can cause the belt to slip as well. Since yours is new, lets hope that doesn't happen.
Good luck.
Good luck.
Yea hopefully my waterpump doesnt mess since its brandnew...so after i put the tape on the threads of the sensor will the steering go back to how it was or will i have to do somethin else
