No pickup included. The pan is set up for a Titan gerotor pump but it can also be used with a conventional style pump.
It would just be figuring out the correct pickup. Stock one might work, I don't know offhand. You could mock it up on your current setup, then measure the pickup clearance and determine if any changes are needed on the depth.
