Where do I order"F" and "Y" are so very different in their mounting, they really have no place in this
where do i order the engine mount brackets? Part # 5 in top pic .."F" and "Y" are so very different in their mounting, they really have no place in this
Where do I order these brackets from?Just thought these might be helpful to some.
Some have thought the right bracket is simply the left flipped upside down.
If you mix up left and right the engine will not be level side to side, if you even get the through bolts in .
The locating lugs are reversed where they contact the mount .
please note the felt pen appears backward
Stamped info below
First pic shows they line up when installed as per factory
Second pic shows how far out you would be if you tried to put the right on the other way .
Side pictures show why they must stay in the correct orientation 10213125 is the left (stamped on bracket )
the left also has that little hole drilled in it
10201937 is the right
1020 (1 missing) 937 (stamped on bracket)
Gerry
Ok thank you I would really appreciate it.If you are looking for 94-96 B body specific engine brackets as in my first post, I may have a set , will check tonight and PM you.
