Did this swap and still having some problems with my gauge.
Originally my gauge would "peg" with the engine running (would read low @ key-on/engine-off). So figured the sensor was bad so decided to do the 0-60 psi sensor swap instead.
Found the resistor and snipped it out of the harness. The two yellow wires appear to be soldered together w/ the resistor, so I left them connected as-is and wrapped it up.
Changed the sensor out with the new one (+ adapter), started the car but the gauge still "pegs" when the engine starts.
Oddly enough the characteristics of the gauge has changed... now it sweeps up to the peg instead of jumping directly there.
I let it idle for a bit and drive in the neighborhood for about a mile. At idle the needle sits at the last tick mark. If I rev it up it actually moved a few mm up higher, then drops back down. It never did this before, it always stayed at the same spot.
Weird
I did notice my sensor came as PN: 19244500 (not the PN: 12553175 listed originally in this thread). It's been a couple months since I've ordered it, I seem to recall the PN had changed basedon a few sites that seemed to supersede one PN with the other... but maybe that was incorrect.
Any ideas?
Weird
Any ideas?
