·For what ever reason my 9C1 doesn't have the rear bar, sorta, just a part of it is still attached to the right LCA. It's way too hot to crawl under the car yet but it looks like either it was cut or the brake was very clean. Anyhow, the previous owner bought a 1" PST rear bar years ago but never installed it. It uses side plates bolted vertically to the LCA's then the bar, with one bolt at the ends and a U bolt a few inches back with the bolts running horizontally to the plate.
My question, is this type of mounting as good/better/worse then the stock style?
Should I find a stock bar from a bone yard or different aftermarket bar, or is this one good?
Thanks.
Thanks.
