Ok I royally screwed up The T27 bolt holding the fuel pressure regulator was stripped and since its impossible to get to the front head to drill out I cut it (Well not impossible I just didn't want to remove the fuel rail to get to it) Ok since I cut the head off and got the FPR off I didn't realize that bolt held the FPR from shooting out from the pressure 馃う
So my only option looks like I need to drill out the bolt from behind/bottom of the bolt.
Any tips on how I should approach this?
Any help is appreciated,Thanks
Sent from my XT1585 using Tapatalk
Banned
you cut the head off so using a left hand / reverse drill bit of a smaller size than the stud. as the drill cuts into the stud it should come out ..
BEFORE YOU PULL THE TRIGGER MAKE SURE ITS REVERSE OR BIT GETS DAMAGED...........
Well I found out that bracket that holds the FPR can just come off. So I just replaced it with another one a fellow member had laying around.
Morale of the story don't be lazy and just take the fuel rail off so you can get to the FPR easier.
